You could try using the following code, but I have set only a simple input variable that will set the temperature for the entire year. Monthly variation has not been provided for. You could create more input variables as per your convenience.
class AddGroundTemperatures < OpenStudio::Measure::ModelMeasure
#define the name that a user will see
def name
return "Add user defined monthly Ground Temperatures"
end
# human readable description
def description
return 'Set the ground temperature to user-defined values for all months'
end
# human readable description of modeling approach
def modeler_description
return 'Adds a specific ground temperature overriding the default energyplus ground temperature of 18 degree celsius.'
end
#define the arguments that the user will input
def arguments(model)
args = OpenStudio::Measure::OSArgumentVector.new
# Define input variables
ground_temp = OpenStudio::Measure::OSArgument::makeDoubleArgument('ground_temp',true)
ground_temp.setDisplayName('Ground Temperature')
ground_temp.setDefaultValue(18)
args << ground_temp
return args
end #end the arguments method
#define what happens when the measure is run
def run(model, runner, user_arguments)
super(model, runner, user_arguments)
#use the built-in error checking
if not runner.validateUserArguments(arguments(model), user_arguments)
return false
end
#set user defined values to variables
ground_temp = runner.getDoubleArgumentValue('ground_temp',user_arguments)
# assign the user inputs to variables
data=[ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp,ground_temp]
# create ground temperature object
groundtemps = OpenStudio::Model::SiteGroundTemperatureBuildingSurface.new(model)
# add monthly temperatures
groundtemps.setAllMonthlyTemperatures(data)
# check the ground temperature for reasonableness
if ground_temp <=0
runner.registerError("Please choose a temperature above 0")
return false
end
# report final condition
runner.registerFinalCondition("The model's ground temperature was changed to #{ground_temp}.")
return true
end #end the run method
end #end the measure
#this allows the measure to be used by the application
AddGroundTemperatures.new.registerWithApplication
You could try using the following code, but I have set only a simple single input variable that will set the temperature for the entire year. Monthly variation has not been provided for. You could create more input variables as per your convenience.
def name
end
def description
end
end
args << ground_temp
return args
return false
end
if ground_temp <=0
return false
end
return true
