There are two approaches for this. If both stories are the same height, you could draw both diagrams at proper z height (working in 3d view so you can see them both. Then run create spaces from diagram once for a one story building and you will get two stories.
A cleaner and certainly more flexible approach is just to run spaces from diagram multiple times.
