Looks like a bug due to a typo here. Feel free to open an issue in the OpenStudio repo. As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio.
https://github.com/NREL/OpenStudio/blame/1e4f9fda38c9a4917b3a4a196a6c9f80d469502c/src/energyplus/ForwardTranslator/ForwardTranslateElectricLoadCenterStorageConverter.cpp#L75-L85
// SimpleFixedEfficiency, optD
optD = modelObject.simpleFixedEfficiency();
if (optD) {
idfObject.setDouble(ElectricLoadCenter_Storage_ConverterFields::SimpleFixedEfficiency, *optD);
// designMaximumContinuousInputPower, optD
optD = modelObject.designMaximumContinuousInputPower();
if (optD) {
Looks like a bug due to a typo here. (see below). Feel free to open an issue in the OpenStudio repo. As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio.
if (optD) {
if (optD) {
Looks like a bug due to a copy/paste typo (see below). below) where the code to ForwardTranslate the _Design Maximum Continuous Input Power_ field is actually setting the _Simple Fixed Efficiency_ field and using the same variable optD.
if (optD) {
if (optD) {
| 4 | No.4 Revision |
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the _Design Maximum Continuous Input Power_ field is actually setting the _Simple Fixed Efficiency_ field and using the same variable optD.
if (optD) {
if (optD) {
As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio, which would look something like this.
# get all objects
electric_load_center_storage_converters = workspace.getObjectsByType('ElectricLoadCenter:Storage:Converter'.to_IddObjectType)
# OR
# get one object, e.g. if there's only one in the model
electric_load_center_storage_converter = workspace.getObjectsByType('ElectricLoadCenter:Storage:Converter'.to_IddObjectType).first
# set Simple Fixed Efficiency field to 0 rather than what's entered in the Design Maximum Continuous Input Power field
design_maximum_continuous_input_power = electric_load_center_storage_converter.setDouble(3, 0)
| 5 | No.5 Revision |
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the _Design Design Maximum Continuous Input Power_ Power field is actually setting the _Simple Simple Fixed Efficiency_ Efficiency field and using the same variable optD. Feel free to open an issue in the OpenStudio repo.
if (optD) {
if (optD) {
# get all objects
# OR
| 6 | No.6 Revision |
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the Design Maximum Continuous Input Power field is actually setting the Simple Fixed Efficiency field and using the same variable optD. Feel free to open an issue in the OpenStudio repo.
if (optD) {
if (optD) {
# get all objects
# OR
| 7 | No.7 Revision |
https://github.com/NREL/OpenStudio/blob/develop/src/energyplus/ForwardTranslator/ForwardTranslateElectricLoadCenterStorageConverter.cpp#L75-L85
if (optD) {
if (optD) {
I opened an issue in the OpenStudio SDK repo here.
https://github.com/NREL/OpenStudio/issues/4174
# get all objects
# OR
