I took a look at the files you posted and found your source of confusion. You are currently reporting outputs for the "Electricity:Building" and "Gas:Building" meters, which indeed do not change between the two files. You probably want to be using the "Electricity:Facility" and "Gas:Facility" meters instead, as these meters include HVAC energy consumption. I switched to these meters in your IDF files and the results changed. If you open up the *.mtd file after running a simulation, you can see what outputs are included in these two meters.
For example, here are the outputs included in "Electricity:Building":
For Meter=Electricity:Building [J], ResourceType=Electricity, Group=Building, contents are:
LIVING HARDWIRED LIGHTING1:Lights Electric Energy
LIVING PLUG-IN LIGHTING1:Lights Electric Energy
DISHWASHER1:Electric Equipment Electric Energy
REFRIGERATOR1:Electric Equipment Electric Energy
CLOTHESWASHER1:Electric Equipment Electric Energy
GAS_DRYER1:Electric Equipment Electric Energy
GAS_RANGE1:Electric Equipment Electric Energy
TELEVISION1:Electric Equipment Electric Energy
GAS_MELS1:Electric Equipment Electric Energy
IECC_ADJ1:Electric Equipment Electric Energy
LIVING_UNIT1:Zone Ventilation Fan Electric Energy
and here are the outputs included in "Electricity:Facility":
For Meter=Electricity:Facility [J], ResourceType=Electricity, contents are:
EXTERIOR-LIGHTS_UNIT1:Exterior Lights Electric Energy
GARAGE-LIGHTS_UNIT1:Exterior Lights Electric Energy
SUPPLY FAN_UNIT1:Fan Electric Energy
MAIN FUEL HEATING COIL_UNIT1:Heating Coil Electric Energy
DX COOLING COIL_UNIT1:Cooling Coil Electric Energy
MAINS PRESSURE_UNIT1:Pump Electric Energy
DX COOLING COIL_UNIT1:Cooling Coil Crankcase Heater Electric Energy
(Note the HVAC outputs above.)
