You can do it via EMS through Sensors getting temperatures, and an Actuator to control actual cooling capacity.
Place an Output:EnergyManagementSystem object in your IDF before running a trial simulations in order to get the EDD file. In EDD file you can find Sensors/Actuators you are looking for to use them in an EMS Program
Here the guide to use EMS
