I've used SankeyMatic for EnergyPlus' End Uses table. It's a quick way to get a diagram without using a data visualization library, e.g. D3.js or Python. I used a spreadsheet with the End Uses table pasted in to create the format required by SankeyMatic.
I've used SankeyMaticSankeyMATIC for EnergyPlus' End Uses table. It's a quick way to get a diagram without using a data visualization library, e.g. D3.js or Python. I used a spreadsheet with the End Uses table pasted in to create the format required by SankeyMatic.SankeyMATIC.
