Given that it seems to be a Heating Loop serving baseboard, and that you have a PUMP:CONSTANTSPEED:PUMP CONSTANT SPEED 1
, and that it gets too hot in the summer, my guess is that it is likely caused by pump heat building up over time indeed.
I can offer two leads:
Switch the Pump:ConstantSpeed
Control Type from Continous
(I'm guessing it's the current control type) to Intermittent
. Read the I/O ref for this specific field, which does mention pump heat buildup too: https://bigladdersoftware.com/epx/docs/9-4/input-output-reference/group-pumps.html#field-pump-control-type-1-000
Use an AvailabilityManager
to switch off your PlantLoop
in the summer months when no heat is required.
