Please go to Output tab in DesignBuilder and then check under General when a zone is selected.
If you do not see Output tab, you have to go under Model Options > Simulation > Output and than chek Allow custom outputs
Please go to Output tab in DesignBuilder and then check under General header when a zone is selected.
