Welcome @cheyenne. I did a search for "output" and found the following posts about getting hourly data from OpenStudio.
https://unmethours.com/question/1936/getting-csv-from-sql/
https://unmethours.com/question/2365/how-do-i-export-output-variables-whos-names-are-located-in-the-rdd-files-in-the-current-projects-run4-energyplus-0-folder/?answer=2381#post-id-2381
Basically OpenStudio doesn't yet output the hourly CSV data so right now that requires one to use EnergyPlus to create the file.
