You say "The custom weather file runs well on energyplus but this problem occurs when simulating multiple fmus through pyfmi."
Does this mean when you use the custom weather file with EnergyPlus standard, it runs. But when you are simulating fmus thru the other interface it does not?
It sound like the 2nd problem is that that interface is expecting only hourly weather files, not the multiple interval files of a minute. Would that make some sense why it fails?
Linda
