Read the input/output reference manual section relative to People. You should also take a look at ASHRAE 55 directly. If you want to see how parameters affect whether it's comfortable or not, you can try the CBE Thermal Comfort Tool which is actually cited by the Input/Output reference.
Factors that come into play in the calculation:
Read the input/output reference manual section relative to People. People. You should also take a look at ASHRAE 55 directly.
