Hi, I encounter the same issue after having defined a dimensionless schedule with a constant value in OpenStudio. In the simulation settings, the "Outdoor Carbon Dioxide Schedule Name" selector is not populated with any schedule so I can't set anything there. Is there a workaround for this?
Hi, I encounter the same issue after having defined a dimensionless schedule with a constant value in OpenStudio. In the simulation settings, the "Outdoor Carbon Dioxide Schedule Name" selector is not populated with any schedule so I can't set anything there. Is there a workaround for this?this (beside using the "Inject IDF Objects")?
Hi, I encounter the same issue after having defined a dimensionless schedule with a constant value in OpenStudio. In the simulation settings, the "Outdoor Carbon Dioxide Schedule Name" selector is not populated with any schedule so I can't set anything there. Is there a workaround for this (beside using the "Inject IDF Objects")?Objects" measure)?
| 4 | No.4 Revision |
Hi, I encounter the same issue after having defined a dimensionless schedule with a constant value in OpenStudio. In the simulation settings, the "Outdoor Carbon Dioxide Schedule Name" selector is not populated with any schedule so I can't set anything there. Is there a workaround for this (beside using the "Inject IDF Objects" measure)?
I have filed a bug report here: https://github.com/openstudiocoalition/OpenStudioApplication/issues/268
