This installer for the 1.1.0 OpenStudio Application should support the latest version of the OpenStudio Results measure on the BCL. If you have an older version of the OpenStudio Application you can continue to use the version of the OpenStudio Results measure that was downloaded when you first started using that version of the OpenStudio Application.
Older releases of the OpenStudio Results measure are also available on NREL's pubic GitHub.com repository.
