You can still download E+ v7.0 from energyplus.net, which should contain the example files. Regarding your v9.0 models, could you just change the version number to 7.0 and see what happens? The simulation will probably fail, but E+ v7.0 should report what's wrong with the model. Then you can check the IDD definitions to "correct" your model manually. Here is an IDD browser you can use: https://app.ensims.com/idd.html
Of course, if you have a complex model or many of them, this will not be a good idea.
