Based on this, I wrote the following function that I've just shared.
def self.get_length(vertices_a, vertices_b)
length = 0.0
vertices_a.each_with_index do |vertex_a, index_a|
prev_a = vertices_a[index_a-1]
vertices_b.each_with_index do |vertex_b, index_b|
prev_b = vertices_b[index_b-1]
p1 = prev_a
p2 = vertex_a
p3 = prev_b
p4 = vertex_b
p12 = p2-p1
p34 = p4-p3
next unless p12.cross(p34).length < 1e-6
p13 = p3-p1
next unless p12.cross(p13).length < 1e-6
p14 = p4-p1
k2 = p12.dot(p12)
k3 = p12.dot(p13)
k4 = p12.dot(p14)
table = [
[0.0, p14.length, p12.length],
[p13.length, p34.length, (p3-p2).length],
[p12.length, (p4-p2).length, 0.0]
row = if k3 < 1e-6 then
elsif k3 < k2 then
else
end
col = if k4 < 1e-6 then
elsif k4 < k2 then
else
end
length += table[row][col]
end
end
length /= 2 if vertices_a.length.eql?(2)
length /= 2 if vertices_b.length.eql?(2)
return length
end
