Hi Carmen,
In order to use values calculated by your Python script for optimisation, you need to add it to the jEPlus project as a "script" object. Your script will take input from jEPlus and produce a table in a required format. The manual is here: https://www.jeplus.org/wiki/doku.php?id=docs:jeplus:v17:manual_1_7_script
A new version (v2.1) of jEPlus and jEPlus+EA is out. It is a little easier to set up RVX in jEPlus v2 and the new jEPlus+EA offers some useful features, too. You can check them out on jeplus.org.
Yi
