Go to Simulation Settings and make sure you have specified the correct date ranges and enabled "Run simulation for weather file run periods". Also, make sure your weather file has a full year. If you downloaded an .epw weather file from DOE, you're fine.
periods".
Also, make sure your weather file has a full year. If you downloaded an .epw weather file from DOE, DOE, you're fine.
