The Schedules tab can only edit and display Ruleset Schedules, so only Ruleset Schedules are shown on that tab. Other schedule types (e.g. Compact Schedules) are shown on other tabs where then can be used or assigned to other objects (e.g. the DOAS zone airflow rate). If you look at your DOAS object do you see the schedule listed there? If you click on the schedule it may show up in the edit inspector where you could see more details about it.
