1 | initial version |
BEopt allows changing schedules for plug loads, most appliances, and heating/cooling setpoints. That comprises the majority of the building energy use, but you are correct that not every energy use can be scheduled in BEopt. Certain complex schedules (e.g., hot water and lighting) that significantly change based on other inputs (e.g., number of bedrooms, location) cannot currently be user-specified.
