Processing math: 100%
Your equation converting J to Wh is correct for the hourly output from EnergyPlus, which could be rewritten as
Whhourly=Jhourly1hr3600s
If you compare the timestep output to the hourly output, you will see that EnergyPlus is already accounting for less energy consumed each timestep. For example, if the hourly HVAC electricity use was 400J, using 4 timesteps per hour would give a timestep output of 100J (assuming constant HVAC consumption). Because of this, you should use the same equation above for converting the J timestep output from EnergyPlus into Wh.
Whtimestep=Jtimestep1hr3600s
