The SurfaceConvectionAlgorithm:Inside object only has those four options. Is there a different algorithm that you would rather apply, or do you have specific convection coefficients that you want to apply each timestep?
UPDATE
You can set both inside and outside convection coefficients by timestep using the Energy Management System (EMS) feature of EnergyPlus. You would need to use the EMS Actuator option to override Surface Convection Heat Transfer Coefficient options using an EMS Sensor that reads the schedule values of convection coefficients and define the EMS Program where the code and logic related to sensor and actuator are defined using the EnergyPlus Runtime Language (ERL), similar to below.
EnergyManagementSystem:Actuator,
Inside_Conv_Coeff_Act, ! Name
East Wall, ! Actuated Component Unique Name
Surface, ! Actuated Component Type
Interior Surface Convection Heat Transfer Coefficient; ! Actuated Component Control Type
Inside_Conv_Coeff_Sens, ! Name
Convection Coefficient Schedule, ! Output:Variable Index Key Name
Schedule Value; ! Output:Variable Name
Inside_Conv_Coeff_Program, ! Name
SET Inside_Conv_Coeff_Act = Inside_Conv_Coeff_Sens;
UPDATE
You can set both inside and outside convection coefficients by timestep using the Energy Management System (EMS) feature of EnergyPlus. You would need to use the following EMS object:
Schedule:File object and See an example of these EMS objects below.
EMS Manager, ! Name
BeginZoneTimestepAfterInitHeatBalance, ! EnergyPlus Model Calling Point
Inside_Conv_Coeff_Program; ! Program Name 1
| 4 | No.4 Revision |
UPDATE
Schedule:File See an example of these EMS objects below.
EMS Manager, ! Name
