You want to add a VRF system instead. Go to the Loop tab, in the dropdown select VRF, then drag a VRF System.
Cf https://openstudiocoalition.org/getting_started/creating_your_model/#vrf-systems
Cf see the documentation at https://openstudiocoalition.org/getting_started/creating_your_model/#vrf-systems
| 4 | No.4 Revision |
| 5 | No.5 Revision |
