@antonszilasi while the pre-populated pull down list comes from OpenStudio standards, all of those fields also allow you to type any string you want for the measure tags. Just keep in mind of you use non-standard tags for your space types then measures like DOE baseline measure or some AEDG measures that rely on OpenStudio-standards won’t work as expected.
If instead you are asking about changing the defaults for your own custom set of inputs, that would require a custom build of the application. An alternative would be an OSM with pre-made space types that you hvae tagged, that can be loaded as a library, then users can drag those space types, including tags, into their model.
@antonszilasi while the pre-populated pull down list comes from OpenStudio standards, all of those fields also allow you to type any string you want for the measure tags. Just keep in mind of you use non-standard tags for your space types then measures like DOE baseline measure or some AEDG measures that rely on OpenStudio-standards the standard measure tags won’t work as expected.
If instead you are asking about changing the defaults for your own custom set of inputs, that would require a custom build of the application. An alternative would be an OSM with pre-made space types that you hvae have tagged, that can be loaded as a library, then users can drag those space types, including tags, into their model.
@antonszilasi while the pre-populated pull down list comes from OpenStudio standards, all of those fields also allow you to type any string you want for the measure tags. Just keep in mind of you use non-standard tags for your space types then measures like DOE baseline measure or some AEDG measures that rely on the standard measure tags won’t work as expected.
If instead you are asking about changing the defaults for your own custom set of inputs, that would require a custom build of the application. An alternative would be an OSM with pre-made space types that you have tagged, that can be loaded as a library, then users can drag those space types, including tags, into their model.
