Great job on thinking about looking at the openstudio-standards gems for reference. However, the method in the gem will not help you because it is meant for SiteGroundTemperatureBuildingSurface (reference).
Which version of OpenStudio are you using? OpenStudio has a binding for the object SiteGroundTemperatureFCfactorMethod as of 3.0.1.
If for some reason you really cannot update your model to 3.0.1, you will need to create an EnergyPlus measure to get the translated Site:GroundTemperature:FCfactorMethod and change the values. For simplicity, I would recommend just updating to 3.0.1.
Which version of OpenStudio are you using? OpenStudio has a binding bindings for the object SiteGroundTemperatureFCfactorMethod as of 3.0.1.
