Are you using EP-Launch to run the simulation? Is the simulation completing successfully? What output files are you getting? If you're using EP-Launch and the simulation completes successfully, what happens when you click the "Table" button on EP-Launch? Alternatively, you can click HTML File from the View Menu.
