A few points...
A few suggestions...
Create Baseline Building measure, i.e. the standard_chs << 90.1-2004 below.``` # Define the arguments that the user will input. def arguments(model) args = OpenStudio::Measure::OSArgumentVector.new
# Make an argument for the standard
standard_chs = OpenStudio::StringVector.new
# standard_chs << '90.1-2004'
standard_chs << '90.1-2007 BETA'
# 1.13.1 onward supports 90.1-2010
if model.version > OpenStudio::VersionString.new('1.13.0')
standard_chs << '90.1-2010 BETA'
end
standard_chs << '90.1-2013'
# standard_chs << 'India ECBC 2007'
standard = OpenStudio::Measure::OSArgument.makeChoiceArgument('standard', standard_chs, true)
standard.setDisplayName('Standard')
standard.setDefaultValue('90.1-2013')
args << standard
You can use any of the available templates to generate a functioning model and then apply measures during run time to match 90.1-2016/2019 performance. These are the ones that come to mind...
A few points...
end
args << standard
A few points...
end
args << standard
