Are you still interested in simulation output data files? I have several output files from a shoebox type of building (Case 600 of ASHRAE Standard 140). The baseline model was parameterized in order to simulate different daily heat gain profiles by combining different variations of parameters such as exterior envelope thermal insulation, window to wall ratio (WWR), and internal heat gains (from people, equipment, and lighting). Additionally, the HVAC system of the original model was modified from an air-based system to a radiant system. Other parameters that are modified in the parametric simulations include design and operational parameters of the radiant system. Let me know if the output from these simulations will help you. Best, Andres.
