It appears you are trying to install the Euclid plugin, not the OpenStudio plugin. You can find a link to the latest SketchUp plugin here: https://openstudiocoalition.org/
If you are trying to install previous versions of the plugin, you can find them here:
If you are trying to install previous versions of the plugin, versions, you can find them here or here: https://github.com/NREL/OpenStudio/releases/tag/v2.9.1
If you are trying to install previous versions, you can find them here or here: https://github.com/NREL/OpenStudio/releases/tag/v2.9.1
