The OpenStudioApplication and the openstudio-sketchup-plugin are now separately maintained by the OpenStudio Coalition:
https://github.com/openstudiocoalition/openstudio-sketchup-plugin
https://github.com/openstudiocoalition/OpenStudioApplication
https://github.com/openstudiocoalition/openstudio-sketchup-pluginopenstudiocoalition/openstudio-sketchup-plugin
https://github.com/openstudiocoalition/OpenStudioApplicationopenstudiocoalition/OpenStudioApplication
The docs are now at https://openstudiocoalition.org/.
| 4 | No.4 Revision |
You'll see in the releases notes for the sketchup-plugin 1.0.1 how to install it: https://github.com/openstudiocoalition/openstudio-sketchup-plugin/releases. You'll need the OpenStudio Application v1.0.1 (NOT the SDK 3.0.1 only) and sketchup 2019 or 2020.
Quoting for convenience:
This SketchUp Plugin is to be used with the OpenStudioApplication v1.0.1 or higher
Installation Steps
1 . Install OpenStudio Application v1.0.1 or higher 2 . Install SketchUp 2019 or 2020 desktop client if not already installed. 3. Download openstudio.rbz plugin 4. Launch SketchUp desktop client. Navigate to: Window -> Extension Manager -> Install Extension -> Browse to openstudio.rbz 5. A dialog box will prompt for root path of OpenStudio Application, e.g. 'C:\openstudioapplication-1.0.1'. It should automatically populate if the OpenStudio Application was installed to the default location. 6. SketchUp should now load the extension.
| 5 | No.5 Revision |
Installation Steps
1 .
| 6 | No.6 Revision |
Installation Steps
