The PixelCounting shadow calculation using the GPU was added in EnergyPlus 9.3. It is not available in EnergyPlus 9.2.
EDIT: So to take advantage of this new capability, you will have to use the OpenStudio application v1.0.0, which corresponds to EnergyPlus v9.3.
