https://openstudio-sdk-documentation.s3.amazonaws.com/cpp/OpenStudio-3.0.1-doc/model/html/classopenstudio_1_1model_1_1_availability_manager_night_cycle.html
You can set these by passing a vector of zones:
bool setControlThermalZones (const std::vector< ThermalZone > &thermalZones)
bool setCoolingControlThermalZones (const std::vector< ThermalZone > &thermalZones)
bool setHeatingControlThermalZones (const std::vector< ThermalZone > &thermalZones)
bool setHeatingZoneFansOnlyThermalZones (const std::vector< ThermalZone > &thermalZones)
and you can reset/clear them:
void resetControlThermalZones ()
void resetCoolingControlThermalZones ()
void resetHeatingControlThermalZones ()
void resetHeatingZoneFansOnlyThermalZones ()
https://openstudio-sdk-documentation.s3.amazonaws.com/cpp/OpenStudio-3.0.1-doc/model/html/classopenstudio_1_1model_1_1_availability_manager_night_cycle.htmlQuoting the SDK doc for 3.0.1 (but this was the same since 2.3.1)
| 4 | No.4 Revision |
These are NOT exposed to the openstudiocoalition/OpenStudioApplication though, you must use the bindings to populate them, or they will be defaulted to ALL zones served by the AirLoopHVAC during ForwardTranslation: You can follow the (quite extensive) logic implemented in ForwardTranslateAvailabilityManagerNightCycle.cpp#L128-L450
