Hi,
While using OpenStudio Application 1.0.0 or Parametric Analysis Tool 3.0.1, you may alter the measure ExportVariabletoCSV a bit to sort out your issue. Replace def arguments() with def arguments(model = nil). A picture of the same is attached here for reference.
