@Abarker Thank you very much for you response. The result that I was talking about was the energy plus HTML.output. As you know, there is End Uses table in energy plus report that you can find all of the energy that is used for heating, cooling, interior lighting, exterior lighting and so on. I attached an example in order to show my method and know your idea about it. C:\fakepath\Untitled23.png
I know my question is so basic because I just started working with Energy plus and openstudio, but I would appreciate it if it is possible for you to show me the Energy Meters sections and related column and row for calculating of TEDI.
I am looking forward to hearing from you.
