1 | initial version |
Check if you have any spaces in your model that are not assigned to a thermal zone. That should issue a warning in the reporting measure for a check of EnergyPlus vs. OpenStudio floor area, and would also cause this section of the report to fail.
2 | No.2 Revision |
Check if you have any spaces in your model that are not assigned to a thermal zone. That should issue a warning in the reporting measure (logged in out.osw file) for a check of EnergyPlus vs. OpenStudio floor area, and would also cause this section of the report to fail.
