I have tried to use the Daikin curves and modeling guide, but it yielded the same results. I believe there is an error in the VRV Heating EIR curve because if i set it back to the default PVVT curve the heating energy is more reasonable.
I have tried to use the Daikin curves and modeling guide, but it yielded the same results. I believe there is an error in the VRV Heating EIR curve because if i set it back to the default PVVT curve curve, the heating energy is more reasonable.
