Yes, this process is called "calibration" since you are tuning an energy model so that it's energy use results match utility bill data for an existing building within a reasonable range. Once that energy model is "calibrated", then you can make changes to resemble the retrofit options and predict their impact. If you search on Unmet Hours for "calibration", you will find LOTS of posts on this topic. Does that answer your question?
Yes, this process is called "calibration" since you are tuning an energy model so that it's energy use results match utility bill data for an existing building within a reasonable range. Once that energy model is "calibrated", then you can make changes to resemble the retrofit options and predict their impact. If you search on Unmet Hours or journal article/conference paper resources for "calibration", you will find LOTS of posts on this topic. Does that answer your question?topic.
