Meters can only be created using "summed" variables (not rate variables)
This warning says it all: Warning ** Meter:Custom="TEST6", variable not summed variable Output Variable or Meter Name="PLANT SUPPLY SIDE COOLING DEMAND RATE".
FYI, I believe documentation and possibly error message will make this more clear in the next release.
Linda
