Hi Rui,
The hourly data extracted to csv for individual cases are stored in the case folders. See example below.
Yi
Hi Rui,
The hourly data extracted to csv for individual cases are stored in the case folders. See example below.below.
You cannot put them in separate columns in the aggregated SimResults.csv with jEPlus alone. However, I think you can do that in Excel quite easily. Try Insert/Pivot Table, and use job_id as column labels and Date/Time as row labels...
Yi
