You need 3.0.0 for WaterCooled VRF to be supported natively in the SDK (Model API), as implemented by https://github.com/NREL/OpenStudio/pull/3613
![]() | 2 | No.2 Revision |
OSApp support is pending: https://github.com/NREL/OpenStudioApplication/pull/185
![]() | 3 | No.3 Revision |
You need 3.0.0 for WaterCooled VRF to be supported natively in the SDK (Model API), as implemented by https://github.com/NREL/OpenStudio/pull/3613OpenStudio#3613
I just added OSApp support in OpenStudioApplication#185
