Hi Eva,
In OpenStudio terms:
Model surface: the "outside" side is the direction the surface normal points, following the right hand rule. Construction: the first material listed is considered the "outside".
In your translated Radiance model, the "outside" material's visible reflectance is used for the shading surface.
