I often end up not using the makeChoiceArgumentOfWorkspaceObject, and instead use a custom version of makeChoiceArgument that gives me more control of sort and filtering. Below is an example for light definitions. Note that the handle is what is passed to the run section, vs. the display name
#populate choice argument for lights_defs that are applied to surfaces in the model
lights_def_handles = OpenStudio::StringVector.new
lights_def_display_names = OpenStudio::StringVector.new
#putting space types and names into hash
lights_def_args = model.getLightsDefinitions
lights_def_args_hash = {}
lights_def_args.each do |lights_def_arg|
lights_def_args_hash[lights_def_arg.name.to_s] = lights_def_arg
end
#looping through sorted hash of lights_defs
lights_def_args_hash.sort.map do |key,value|
#only include if it is used in a space, and has a non 0 value
if value.quantity > 0 and not value.wattsperSpaceFloorArea.empty?
lights_def_handles << value.handle.to_s
lights_def_display_names << key
end
end
#make an argument for lights_def
lights_def = OpenStudio::Ruleset::OSArgument::makeChoiceArgument("lights_def", lights_def_handles, lights_def_display_names,true)
lights_def.setDisplayName("Choose a Watt per Area Lights Definition to Add Costs to.")
args << lights_def
Below is what would be in the run section
#assign the user inputs to variables
lights_def = runner.getOptionalWorkspaceObjectChoiceValue("lights_def",user_arguments,model) #model is passed in because of argument type
#check the Definition for reasonableness
if lights_def.empty?
handle = runner.getStringArgumentValue("lights_def",user_arguments)
if handle.empty?
runner.registerError("No Lights Definition was chosen.")
else
runner.registerError("The selected Lights Definition with handle '#{handle}' was not found in the model. It may have been removed by another measure.")
end
return false
else
if not lights_def.get.to_LightsDefinition.empty?
lights_def = lights_def.get.to_LightsDefinition.get
else
runner.registerError("Script Error - argument not showing up as Lights Definition.")
return false
end
end #end of if lights_def.empty?
@macumber may have examples on how to use the makeChoiceArgumentOfWorkspaceObjects. I think it handles sorting now by object name, if you don't want to filter it.
To address you question of selecting multiple objects, there are a few possible solutions, none of the very pretty.
Update:
Option 1 would look something like this.
# argument would be something like "Zone 1,Zone 2,Zone 3,Zone 4"
example_argument= runner.getStringArgumentValue("example_argument",user_arguments)
# split string into an array of selected thermal zone names
selected_zone_names = example_argument.split(",")
# add thermal zones from argument to array
selected_zone_objects = []
model.getThermalZones.each do |thermal_zone|
if selected_zone_names.include? thermal_zone.name.to_s
selected_zone_objects << thermal_zone
end
end
# add warning if there two arrays are not the same size
if selected_zone_names.size > selected_zone_objects.size
runner.registerWarning("One or more of the entered zone names could not be found in the model.")
end
