I got something working in python with a few blemishes. Python's recommended subprocess was interfering with multiprocessing, so I had to use the ill advised os instead.
rungroup.py
from multiprocessing import Pool
import os
import time
def run_energyplus_cmd(command_string):
print('starting ' + command_string)
start_seconds = time.time()
os.system(command_string + ' >NUL 2>&1') #concatenated string for suppressing energyplus output
elapsed_minutes = int((time.time() - start_seconds)/60*100.0)/100.0 #two decimal places
print(str(elapsed_minutes) + ' min for ' + command_string)
if __name__ == '__main__':
number_of_simultaneous_simulations = 4
#read commands.txt and split lines into array
commands_file = open('commands.txt', 'r')
commands_array = commands_file.read()
commands_file.close()
commands_array = commands_array.splitlines()
#run all commands in parallel up to number_of_simultaneous_simulations at a time
with Pool(number_of_simultaneous_simulations) as p:
p.map(run_energyplus_cmd, commands_array)
#using energyplus on the command line versus EP-Launch had different output
#cmd made <idf_name>out.eio but EP-Launch made <idf_name>.eio output files
#this is to remove all the "out" strings from the output files
folder = 'runs'
for filename in os.listdir(folder):
filename = os.path.join(folder,filename)
if not os.path.isfile(filename): continue
new_filename = filename.replace('out.', '.')
try:
os.rename(filename, new_filename)
except WindowsError:
os.remove(new_filename)
Here is my file organization. Folder "runs" contains all my IDFs, "weather files" contained my EPWs, and commands.txt contains the Windows cmd input.
commands.txt
C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run0 -d runs runs/run0.idf C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run1 -d runs runs/run1.idf C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run2 -d runs runs/run2.idf C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run3 -d runs runs/run3.idf C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run4 -d runs runs/run4.idf
Lastly, the output.
C:\Users\<YOUR NAME>\Desktop\multiprocessing>python rungroup.py
starting C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run0 -d runs runs/run0.idf
starting C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run1 -d runs runs/run1.idf
starting C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run2 -d runs runs/run2.idf
starting C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run3 -d runs runs/run3.idf
0.26 min for C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run2 -d runs runs/run2.idf
starting C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run4 -d runs runs/run4.idf
0.27 min for C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run3 -d runs runs/run3.idf
0.27 min for C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run0 -d runs runs/run0.idf
0.27 min for C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run1 -d runs runs/run1.idf
0.16 min for C:/EnergyPlusV9-3-0/energyplus -w "weather files/CZ03/CZ03.epw" -p run4 -d runs runs/run4.idf
