As a short term solution for those experiencing this issue, the GBXML data exported from the SketchUp 2019 using OS V1.0.0 plugin can be re-imported into a downgraded version of the SketchUp OS plugin combo. It appeared that the resulting .osm file was intact, so I exported as GBXML again. It imported successfully into HAP.
Downgraded versions used: SketchUp Pro 2018 & OpenStudio 2.8.0 which is available on the OS github site
