Somewhere in your input file (IDF) there is a Material object where the first input field for Name is blank. This can be inferred from the specific error line copied below.
** Severe ** <root>[Material] - Object name is required and cannot be blank or whitespace
Your Material object might look something like below, if you are editing the IDF in a text editor or IDF Editor that comes with EnergyPlus:
Material,
, ! Material Name (this is an example of a blank input field)
Rough, ! Roughness
0.1014984, ! Thickness {m}
1.245296, ! Conductivity {W/M*K}
2082.400, ! Density {Kg/M**3}
920.4800, ! Specific Heat {J/Kg*K}
0.9000000, ! Thermal Absorptance
0.9300000, ! Solar Absorptance
0.9300000; ! Visible Absorptance
