Your first error is because EnergyPlus requires all surfaces have a construction assigned. If you plan on only using the OpenStudio SDK through measures for your workflow, then I would recommend searching for "Assign Construction" on NREL's Building Component Library (BCL) to see what existing measures you can download for free and either use right away or use as a starting point for creating your own custom measure(s). Assign Construction Set to Building is likely your best bet, but that will require that as a first step you also use a measure to create materials, combined those materials into constructions, and then group the constructions into construction sets. The Space Type and Construction Set Wizard may be a good reference or starting point for that as well.
