The Parametric Analysis Tool isn't intended to run a single simulation. Try adding one or more measure to your workflow with at least one measure argument used as a variable. Make sure project should have two or more design alternatives before you try to run it.
click to hide/show revision 2
No.2 Revision
The Parametric Analysis Tool isn't intended to run a single simulation. Try adding one or more measure to your workflow with at least one measure argument used as a variable. Make sure your project should have has two or more design alternatives before you try to run it. it.
