Are you doing some little modifications to IDF through IDF Editor before running? if so, check "File" > "Save Options" >"Original with New at bottom" to keep your preferred order
![]() | 2 | No.2 Revision |
Are you doing some little modifications to your IDF through IDF Editor before running? running it through EP Lunch? if so, check "File" > "Save Options" >"Original with New at bottom" to keep your preferred order
order
