Yes, you can do that through the detailed interface. Once you've generated your model using the Wizard, got to Mode and click on Detail Data Edit. Then you'll be able to customize constructions through the Building Shell tab.
Yes, you can do that through the detailed interface. Once you've generated your model using the Wizard, got go to Mode and click on Detail Data Edit. Then you'll be able to customize constructions through the Building Shell tab.
