You can create a condenser loop, add a cooling tower and boiler on it, and then connect "Water to Air HP" coils to it (see below).
When you add a "Water to Air HP" in a zone it gives you the option on the top to connect it to loops, choose the condenser loop you created.
Also, you can use the script on the BCL called "WSHP with DOAS (More Design Parameters)". This will build the system and then you can edit it as you wish in OS.
