Hi, I've always worked (very fine) with a simple TXT file (filled with data from a spraedsheet) and DEF file (filled with the conversion instructions).
You may find useful looking at Elements software; it depends up to the magnitude og the modifications you need to do.
Ag
Hi, I've always worked (very fine) through the WeatherConverter E+ auxiliary software with a simple TXT file (filled with data from a spraedsheet) and DEF file (filled with the conversion instructions).
Ag
